No pics or measurements mate?I take it I have measured the wrong bit but would I be right in saying these are cup hubs ?
You need to measure the centres of the bolt holes mate, but I'd hazard a guess that they're 54mm non cup packed hubs if we are talking 182's as they are 60mm centres, but they're cup hubs if we are talking 172 cup. Make sense?this is it
You need 182 cup/cup packed hubs by the sounds of that then mate.Well I have some avo suspension that won't fit as in the holes are to close, it's not a cup car but I'm guessing someone has fitted cup hubs
You need 172 hubs then mate, or alternatively get the avo's machined to suit. You just need to get one of the holes elongated so they suit 54mm or 60mm spacing hubs.It's a 182, but the avo coilovers I have the holes are even closer together
Are you measuring the hole centres? That's what you need to be measuring on both items.this is the measurements I took from the avos
1st pic shows a measurement of 46mm. Bolt holes are 14mm, so that gives a 60mm spacing.measure as you've done then measure one hole, add that to the first measurement and that will give you your centres.
2nd pic shows a measurement of 40mm, so same theory applied gives hole spacing of 54mm.
Lol!i'm lazy though and didn't look at the pics:wink:
