Good question. I'd love to know this too.Hi,
I want to put the 197/200 rear hubs on a 182. This is to mount the 197/200 break callipers. Will the hubs fit?
Has anyone tried this before?
That was myself and @nath&alex that did that.@NorthloopCup and someone else developed a kit. Means you lose the abs but apparently the bearings last longer.
He's just used some 240mm clio mk3 discs, calipers and stub axles.Noos has done it by the looks of it. But the calliper doesnt look like it's mounted in the same place ad a 197
Has he just made a custom bracket?
That way you could keep the standard set up
What are you trying to achieve? Do you just want to run 197 rear calipers on standard sized discs?So if you wanted to keep the abs. The only thing you can do is make a custom bracket on the existing hub to mount the carrier...
And also seize. The pistons are also too large so you'll upset the rear brake balance.Nothing, apart from they are easier to service. Sliding callipers always seize. The 197 callipers are smaller and look better.
