leedsboy
Bean 182 + E70 X5
As I've removed the rear spacers that had camber on causing the rear to be off, the lad from the garage who did my alignment seems to think they're going to want to charge me again as now all the front end will be out as the system uses the rear to calibrate the front?
Thing is, the steering wheel is off-centre, and was off-centre when I left the garage. I am booked in for this saturday morning, but if they're going to end up charging me again, i'd rather get some 10mm spacers on the back end and resolve a knocking noise i've got. Thoughts?
Doesn't make too much sense to me, as i'd have though the rear is the rear, and the front is the front. So regardless the front with 6 degrees of toe will always be that.
If you want some rear 10mm spacers, let me know. I've got the 10mm ones sat in the garage that you can buy off me as I replaced them with 5mm ones
