imprezaworks
Mk5 Golf GTI :)
Forward thinking ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Soooo... can you group N time a set of 197 cams?
Some good reading here, who is all offering group n timing then? From what Iv gathered in this thread its bloke and EFi? Is it just the labour involved for the belt change / timing setup and then mapping on top? Would be good to know a rough cost.
Is mapping necessary top take advantage of the Group N timing?
after the idle tweak, can it be driven to and from a mapping session?will pm you later but the price varies, phase 1 is cheaper though.
100% has to be mapped
say about 150Km?
Can I have a quote pleaseYeah, as long as you don't hammer it. If you've got much stop starting or at in traffic a lot be prepared for the fuel to be all over the place and slow to drop as well.
If one had Cat Cam 428s already installed and were doing belts, could you:
a) Use Oe renault timing gear
b) Only use Cat Cam timing gear
c) Use Group N timing gear or
d) none of the above ?
At your own risk, but I’d say no tbh mate. I know what RenaultSport did on the R3 access cars, and if it worked well, they would’ve used it. But they didn’t.can the tool be used on197 / 200 's?
Tnx mate, I have some interested 197 owners on this end Had to make sure.At your own risk, but I’d say no tbh mate. I know what RenaultSport did on the R3 access cars, and if it worked well, they would’ve used it. But they didn’t.
