Clio 2 RS172 Cup
Does anyone have any experience with loosening and straightening the rear beam? Is there even any movement available to do this? Car has been partially set up with camber bolts on the front. Depending on what I can do with the rear will dictate the overall setup. I should mention it has Bilstein B14s and has been corner weighted. Also, what do you think to the caster difference up front? It has brand new wishbones.
I've got a bunch of shims to go on but I'm wondering if the beam is actually bent. So should I shim it or do I have a bigger problem on my hands. Any opinions are appreciated
Cheers!
Cheers!
