Touring_Rob
Hi there,
Since having engine out and replacing all the mounts I just cannot for the life of me adjust the gear selector rod properly.
Had the Mrs hold it in a neutral like position, after much tweaking I can select all gears bar reverse. I can select reverse manually from under the car (bit inconvenient ) and if I go very quickly from right to left can occasionally get it to jump into reverse. Feels like a am only a mm or so away from winning.
Does any one have any helpful tips on adjusting the mech well? Rather than just lying under the car for hours moving it slightly?
Thanks!
Thanks!
