182 Passenger Front Footwell Water Ingress
  182
The issue I’m having might have been covered before so apologies in advance, with all the rain we’ve had I’ve noticed water pooling on top of the passenger door seal towards the front of the car and eventually trickling into the footwell. I’ve included a couple of pics. The carpets aren’t wet anywhere apart from the small area circled on the pic. Could it be the door seal or other drain holes else where?
Thanks
Gus
  182Turbo,DCi90
Thanks James, I’m struggling to access that link due to permissions. Might be because of new account.
Its in the guides section so you need to be a paid up member. Well worth it though, that guide has everything you need to know.
TheEvilGiraffe
South East - Essex
It's a members only area.
£10 and you're golden.
Also worth checking the rear lights as the rubbers often dry out and let water in too... check boot area for water too.
JamesBryan
Ahh yeah, you need to be a paid member to see it.
Basically you need to take the door card off and redo the seals.
You must be the other silver 182 i've seen around Warrington?
  182
Okay thanks, I’ll have a look
I’ve done the rear grommets with sealant, definitely water tight was leaking at some time in the past I think.
Mr Underhill
Thanks
100% door card seal. Door card off, Butyl Sealing Tape (tenner on Amazon), jobs a good un.
Here's mine.
  182
Thanks for the help and guidance, I’ve had a similar problem with a VW in the past it sounds like the water is getting in the exact same way.
