so it can be done by hand? thats all I wanted to hear![]()
No not always last time i changed the filter on mine it must not of been oiled on the seal the previous time and was tight as f**k
so has to use the filter strap.
Girl hands ftl
I really would replace it every time (should cost ~50p from a local motor spares/factor). I tried to script before and got an annoying drip-drip.Also do you really need to replace the copper washer when replacing the oil? Can you just walk into Reno and get one?
No.
1) Wipe the filter with a rag (touch of white spirit if you like)
2) Try turning with your hand
3) if you really can't shift it, use a fairly sharp screwdriver and a hammer, punch the screwdriver all the way through and turn.
Screwdriver :nono:
Proper, full on, n00b question, change the filter before or after changing the oil? Or whilst it's empty?
I can honestly say I've never bothered to change one myself before.
CS card? In Renault? Really? I imagine they'd just look at me like I'm a nut.
I've already ordered a bosche filter from ECP, so just need me a washer.
Wear rubber gloves, makes it really easy to grip.
yeah renault are just as cheap... for the price I always use genuine filter (like £1 more than a motorfactors branded one)
Surely a bosche one will be just as good? I just need to go get a sump washer from somewhere, Renault isn't an option for me, as now....
"Parts close at 5 and no London brances are open weekends"
Screwed.
Bugger, need to get me to a Renault, actually I'm off Friday, touch.
