Re: Boosted BlackGold Project - F4rT content.
The long awaited engine conversion update!
Didn't make it to CSS due to being offered a good days work on Saturday
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Then last night i stupidly decided to go out on the beers with my mates, so i got in at 4 and needed to be up at 7:30 to get to DannyR's to collect these
Got back home about 10:30 and cracked on with it, was really taking my time today as i've like sh*t lol. This is when i started.
Soon enough it was getting stripped apart.
I then found out what had been causing my intermittent stop light coming on, the abs sensor wire had melted out exhaust manifold.
At some point the engine came out for new gearbox and clutch, and who ever done it routed the wires terribly, the gearbox mounts were loose, bolts missing and alsorts! The clutch had seen some serious heat in it's life too!
And by about 2:30 the engine was out, i then took subframe off too, for powdercoating, then pollybushing before refitting.
I then spent what time i had left putting bits on the engine, flywheel, clutch, 182 cam cover and top engine mounts. I also gave my 225 inlet manifold a coat of VHT paint
So by the end of the day my garage now looks like a clio brakers yard lol.
It was also nice to find a K&N panel filter and that i had RS stamped lower inlet
Next update will be once i've cleaned up engine bay and engine is built up, need to get lots of parts off for powdercoating too!
