15x7 Kosei K1-TS (ca 5.5-6.5 kg per wheel). Rides really well when compared to OEM 16'' 172 wheels.
I was thinking the exact same thing lolIs your picture backwards or am I getting crazy?!
+1 lol.
Mint. Very nice! Has this been lowered? If so, what springs? I want to lower my clio, its only a 1.2 but never the less!
Do the BMW bbs fit straight onto a clio
Looks like you have to get them rebored from his project thread. They do look good tho !
Might consider a set as track wheels![]()
Liking the e30 wheels, are they heavy?
Yeah had to get them rebored. The bore was 57.1 and they had a lip which they sat on. Once that was machined off the bore after that was millimeter perfect to 60.1.
Should do it!
Cheers, unsure on weight but I replaced them from some 6.5kg per rim, they were similar maybe heavier but that could be due to different tyre profiles that were on.
Not badthey are ET24
Did they fit okay? I'm looking into getting some wheels with an et25 offset, did you run spacers?
Fit fine no spacers needed. May run camber + spacers at rear but you'll have no problems, I'm lowered about 60mm and the wheels are 7j with 195/50 tyres.
What Tyre sizes would you recommend for 6.5j 15s?
Also does anyone have a picture with them fitted to a standard ride height 172? As I will be using for winter tyres.
