172 Cup starting problem
Prong
I have an intermittent starting problem with my 172 cup. I have gone a month since the last time it's done this.
When starting the engine turns over but does not fire and the fuel pump doesn't seem to be running. sometimes it takes 3-4 times to start other times it can be 20+. I have changed TDC sensor and checked the battery for loose terminals ect. I have had mechanic mate of mine check it out and he seems to think its an immobiliser issue?
Any ideas?
  Clio Sport 172
Had same prob with my 02 172 about 5 weeks ago.
Does your red light on the dash go out when you try to start it?
If not the immob is not disarming....
I took mine to renault and the put it on the computer..
They cleared some faults it had, cleaned my relays which were correded and resynched my key....£65.....
No probs since ( touch wood )....
