RS 172
I've just put my car up on the ramp at wrk to have a look to see if i could find something that is causing a knocking under hard acceleration.
Exaust doesn't appear to be moving, bottom engine mount seems ok, with my limited knowledge i couldn't see anything that would be causing a knocking.
But...
One of the technicians noticed there was a bit of movement in the n/s/f wheel, when lifting the wheel up from underneath there is a bit of movement. Looking at it from the top mount under the bonnet it moves up about 15-20mm at most. Could there be a worn bush somewhere or something else causing it??
Any help/advice would be greatly appreciated!
Thanks.
Mark
But...
Thanks.
Mark
