he was querieing the point of doing it, which on stock cams, there isn't one. Do you understand rhetoric?it is kinda weird, remapper from a known company (guess who-tec) does not know about it.
that's impossible on a 1*2. Can be done on a 197/200 thoughAs far as I know, Henk can even activate it with different advance angles if required.
That depends on the calibration version as well.in satandart the vvt opens at 1600rpm and closes at 6500rpm
in your ecu program you can adjust it more higher closing points
