Hey. Anybody know how to stop the passenger seat on my cup from rattling on the rails? Its v.annoying! Is there a way of tightening them, or should there be an insert on it like on the drivers seat? Cheers
Best idea is to remove the seat as there more space then.
4 bolt under the car covered with rubber bungs the two near the edge are easy to find. The other two are on the central tunnel of the car so you've got to get right under the car to find them.
Might just be those bolts which are loose. If not then unbolt the bolts unplug the pretensioner then take the two covers off the sides of the seat and you'll see the other 4 nuts bolting the rails to the seat (two on either side they can need tigtheing. With the sides cover of check the bolt holding the rear of the seat on are tight.
