Clio 172 Ph1
I have a ph1 & ph2 (both track only cars) Looking to get a set of AST's 5200's for the ph1 as a race setup but have a few questions
Current ph1 set up = Cup wishbones, PMS top mounts & brace, polybushed etc.
1) What top mount should I get that allows easy adjustment of camber from the top ?
2) With the cup wishbones do I need a top mount that will allow more castor adjustment or do I have enough
3) Bearing in mind the two points above, do I need the PMS brace and is it compatible with the new top mount options?
4) I am guessing that all this would be transferable to the ph2 if it were needed ?
5) What recommended dry versus wet camber / toe set up would be recommended ?
Appreciate your feedback
