balanced and lightened flywheel for 172
  lift number 1 @ btm
just wondering if anyone has done this, or knows if it is worth bothering with?
i'm about to have a bottom end rebuild anyway, so the flywheel will be removed in the process.
does anyone know the weight of the standard fly, or the weight to aim for if i do have it machined?
any info at all would be appreciated. :)
no idea if it would do anything really, but the local garage near me quote £40... as they are a rip off I'm guessing it should be cheaper... plus if they did it chances are it would f**k up
  lift number 1 @ btm
thanks, thats cool. they guys doing the work are pretty spot on to be honest, so that isn't an issue.
has anyone actually done this? or driven a car with it done? just wondering if it will end up making me have to double de-clutch everywhere!
Yozzasports cup has it done I think.
  182cup & 172 racecar
NO YOU WILL NOT,and it will be worth it.
  Clio 182
It is worth it, my williams engine has a lightened and balanced flywheel and it rev's a lot free'er
  C63 AMG, F430 & 172
you should really ballemce the crank too the flywheel.
looking at 130 ish iirc
speak to BenR
M
mini-valver
If you're going tobe really revving it then it can work against you aswell as you lose inertia top end from what I've read.....
  lift number 1 @ btm
so.... thats as clear as mud then!
i'll go ahead and do it just to satisfy my curiosity then, i'll only be torturing myself if i dont! plus mr hunter always seems to know what he is on about!
cheers all!
