Bilsteins B14 / OE top mounts
Sheen90
  172 Turbo
Hi,
I've just fitted the front coilovers with the OE top mounts. When putting back on the car, the top hat now sits about 5-10mm above the tower. Is that correct or have I got something wrong?
Thanks, Callum
Jekyll
Adam, where did you get your Bilstein top mounts from? Or was it through your friend?
Are they better than the Renault ones? Or is it just that they fit the bilstein coilovers better due to the thread pattern?
adamlstr
They're just a replacement for standard ones mate, as I was fitting Bilstein coilovers I figured I'd get new top mounts at the same time.
Any Bilstein dealer should be able to get them.. 12-244690 is the part number.
