brembo HC over MAX
  172 cup
Why do so many people opt for the high carbon discs instead of the max? Are the max discs not as good or do they wear quickly? Just noticed so many people get the HC in the short time i've been on this site and wondered why :S Thanks
  BMW F21 125d
Price was one factor for me, but also reviews on here of the HC are good. I have Brembo HC and EBC Green's.
Brembo HCs can be got for £60, where as the Max are £120.
  340i
HC for perforamnce
MAX for looks
Thats what my friend was told the other day when buying a good track-based braking set up.. the bloke at Demon tweeks said i wont sell you the Brembo max discs because they arnt as good LOL!
Cue
  182 Trophy #274
Max are HC but with grooves
they aid cooling and wet braking performance. For everyday road use the extra money isn't worth it as you'll never really generate enough heat to need the cooling and you shouldn't be driving that hard to need the grooves in the wet.
  TVR Cerbera
are you sure the grooves are for wet braking performance? i personally don't know or heard of that one. i know drilled are top end high performance but are prone to cracking.
Cue
  182 Trophy #274
you may be thinking of the drilled ones, they are more prone to cracking. As I said though the Max are High carbs but with the wear indicator grooves.
  TVR Cerbera
that's what i said, drilled ones can crack. thought you said max ones are to aid wet braking, or are they wear indicators?
Cue
  182 Trophy #274
the principle purpose is wear indicators, but the grooves do aid cooling and the dispersal of water from the disk.
i.e. ina down pour you get instant braking rather than needing to tap the brake first to dry them. Having said that it's irrelivant if you go for a race or fast road pad as their operating temp is higher than the oem ones.
MarkCup
I thought the grooves were to stop the build-up of gas you get fizzing out of a pad from the pad material binding resin when it's hot.
That's what fade is, a layer of gas between the pad and disc I thought, and the holes or grooves allow that cushion to be periodically broken.
Does that make sense?
Steve
  ST3 8.5
Spot on mate.
Cooling via vents inbetween the friction surfaces.
Cue
  182 Trophy #274
yep also why drilled disks work, the grooves work with centrifugal force.
There's a whole range of benefits to grooved disks but brembo only list them as wear indicators, although the technitions real off allsorts of actual benefits.
Of course none of them really make difference on the road, so the extra £ can be money saved with HC disks.
Keith185
Yozzasport recommend the plain discs over Max when used with ferodo DS2500 pads.
Also DS2500 wear the discs quicker than other pads, around 3:1 discs to pads.
It depends entirely on which pads you are choosing and for what application as to which package we recommend.
Max are the best choice with specific pads in specific circumstances. Plain in others.
/y0z
  172 cup
I'm not too bothered by on road performance. I very rarely drive fast on the road so am looking for a brake set up suited more for track days. At the moment from what i've read i'm thinking of going with pagid blues. What disk would be best suited to these? Or are ds2500 better?! I don't want the carbon lorraine jobbies though because i don't like the sound of how much brake dust they build up
ps soz this is a bit off topic now, wasn't sure if i should start a new thread or not
  Monaro VXR/Cupra TDi
Max disc's for 90 quid on e-bay delivered. Bought mine, happy with the price and product.:)
I'll second that about the water disappation.
Hard driving in down poor last week, excellent response from the brakes immediately.:)
  Audi TT 3.2 V6
I got mine for £80 using GSF's ebay store, they had best offer facility setup so i made an offer...they accepted. couldnt beleive the bargain price.
