bumpy rear
  Black 182 + Recaros
The rear of my 182 Cup seems more bumpy than usual. I suspected the dampers but Renault can't find anything obvious. They unscrewed the dampers from the wheels and tested the dampers for resistance. I was standing there when they did it.
The tyre pressures are okay. I believe the balancing is okay, but not 100% sure.
A recent tracking reports shows the following-
- left rear camber is -2'05 degrees (outside the normal specifications)
- right rear camber is -1'02 degrees
- left rear Toe is - 0.1mm
- right rear Toe is - 2.0mm
Any suggestions ?
  Black 182 + Recaros
Replacing the rear tyres has resolved the problem.
They were worn down and only just legal. The car handles so much better now.
Thanks for all the suggestions ;)
  Black 182 + Recaros
D1CKY - I dont understand.
The worn tyres made the ride feel more bumpy. I was surprised by this, but replacing them did cure the problem and also made corning feel much better. Sticking new tyres on the back is my advice.
