Camber, Geometry & Suspension info...
Cue
  182 Trophy #274
Does anyone know a good company in either the NW or Yorkshire akin to Mark Fish?
Steve
  ST3 8.5
Anywhere near leics, notts or derby???
Asked this ages ago, drew a blank;)
  Not a poxy Renault
Only a few miles further Steve, but Northampton Motorsport is meant to be pretty good, though I've not used them myself........yet!
Cue
  182 Trophy #274
seems all the suspension specialists get nose bleeds north of brum.
  megan R26.R number 006
yozzasport are Stafford there is hill power in Darby i think that he dose the camber set up and there is one more place in Stafford ;) i hope this helps you m8
Cue
  182 Trophy #274
Even better, A&G Auto Engineers in Elland - jnct 24 of M62. They've set-up a few race cars.
I've used them before, they fitted the brakes etc, didn't know they did geometry work though..
  Renaultsport Clio 172 Cup
I had the front and rear cambers set up by Xtreme Motorsport which is near Alrewas, just off the A38. He used to run Clio Cup racers and had the rear shims in stock. The front camber bolts he used on my car are actually 14mm so the hub and front strut had to be drilled out to suit. All in with the shims, machining and set up came to around £200.
The fronts are currently -2.5 deg and the rears are - 2.0 deg with a bit more toe in to suit.
