Recently my amp has started cutting out intermittently. I have a fair knowledge of this subject so I have already checked the following.
Engine off: voltage at battery - 13
end of amp power cable at fuse - 13
end of power cable at amp - 13
Remote wire - 0
With the engine on the voltage at the amp is circa 6.5 volts. The remote wire is 12-13 volts. I've inspected all wiring and all fuses which are all fine. Starting to suspect dodgy amp but would be grateful if any auto electricians on here could help.
Remote wire - 0
