Charger and epas
Hi guys, food for thought,
Running a rotrex c30-94 and epas, I can't use a pms pas delete kit as they say it doesn't work with standard pulleys however does anyone know if I can run a 1.2/1.5 clio pas idler instead from the mk2 ph2 setups?
Thanks in advance
  SQ5
Why can't you just use the normal PAS pump, with the supercharger sucking so much from the crank the PAS pump is so minuscule in difference.
No, it's too big.
It's too big as in the pulley? Or the mount doesn't fit inside the normal 172 pas mount?
I already run epas it's a lot more effort to revert back.
Is it possible to bolt the standard pas pulley to the pms assembly?
I will design a bracket if this doesn't work
