Churping Brakes??
  Clio 182
Hello, wondering if someone can help, ive recently changed my brakes disc's and pads, when im cruising around 35-40 i can hear a little whistling/churping noise from the drivers wheel anyone have any ideas? thanks..
  RB 182 & Lotus Evora
Did you use new shims? did you use copper grease on the back of the brake pads? If not pull it apart and check. The shims/springs are needed to keep the pad stable and not move about when no brake load
