Cigarette lighter
  Clio 197
Hey guys, any have any idea about why my cigarette lighter doesn't work on my 197? And how easy are they to sort out?
Check fuse first. If not then put a multimeter on the connections of the socket and see if it has power. If it doesnt and the fuse is ok then most likely a loose wire or earth somewhere. Also, have you tried other 12v accessories to check its not the one you're using that's broken?
