clio 182 compression test
  PH1 loads of boost!
Standard good compression is about 190. But all your results are within 10% of each other which would suggest if it is down on power it could be due to cam timing.
Cheap compression gauges sometimes dont give true results, though. If they're all even (which yours are) and you've no other symptoms it could be fine.
