Clio 182 idle at 2000+ rpm
colesy61291
  Renault Clio 182
Hi I have a 182 witch is standard appart from a bmc cda air filter and samco intake pipe and the acoustic valve removed
Diagnostic scan coming up with bi- mode air inlet solinoid valve
The car is revving at 2000+ rpm on idle
So far I've cleaned and changed the throttle body , new inlet gaskets upper and lower, checked all the vacuum pipes on inlet and changed both sensors in the upper inlet
Nothing has helped
Anyone with any ideas
Jekyll
Yep, air leak.
Have you checked the gasket on the throttle body to inlet? I had the same issue with mine and it turned out to be the throttle body gasket. Only a couple of quid from renault.
I take it all plugs are clipped in?
colesy61291
  Renault Clio 182
The orange seal is fine
And yeah everything looks normal
Is it possible to have a crack in the manifold ?
