Clio 200 gearbox troubles
ado
  기아 &#4
Been experiencing this for quite a while now but no one can find a fault. Basically I cannot select any gears at all for around 30s.
Conditions are:
8/9C (I guess 6-10C)
Cold engine/gearbox (left overnight)
Weirdly any colder or warmer than it's perfectly fine.
Took a vid on my phone.
Booked in again next week so hopefully it'll be sorted.
ado
  기아 &#4
lol
RUK did ask if I was keeping the car. I think the time for a new car has just got closer if they don't fix it.
Gaz_
  Extreme mode
Is the general consensus not he gearbox, but a slave cylinder issue? Sure Ive read it somewhere?
ado
  기아 &#4
What would be the symptoms of a failing slave cylinder? Currently it's fine after 30s and only happens at a certain temp.
  GTD, Lupo
How many miles has the car done? My old 200 was sometimes a b**ch to get in gear when cold but after about 15k the issue just disappeared!
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
I'd say thats more likely to be a clutch master or slave cylinder issue rather than the box itself. Checked the brake fluid level recently? My Laguna was struggling to select 3rd when cold and just seemed to hit the gate on a PK6 box but as it warmed up it would finally crunch in as if the synchro was shafted and then eventually, when it was up to temp, it would select perfectly.
changed brake fluid, bled all four wheels and the clutch slave and boom, issue resolved!
Mick
ado
  기아 &#4
Fluid changed and bled at the end of summer. Due another change though so will see how it is.
ado
  기아 &#4
nope. I sold the car in 2012 and the gearbox is still he original one.
