clio discs - 280mm diameter
F1 discs - 278mm diameter
just saying LOL![]()
F1 car = small mass, high speed but less braking required as can carry more speed through corners (thus duty is less) = small brakes.
Standard clio disc 280mm 7.1kg each - Ali bell and 295mm Ap discs 5.5kg = 3.2kg saving
Standard caliper 5kg +? - AP caliper 1.9kg = 6+kg saving
Nearly 10kgs by changing the better brakes too.
ps. seems to me that swede cup is assuming you wouldn't go faster on the straight going into the corner if you had more power - that's the only way I can make sense of what he is saying :s
Chip spoke about a setup for Lesley's car as he has already built his setup. Not at one point did I say he didn't need bigger/better brakes, its a given with more power. What I did say was that imo my setup would suffice for Chips car with a better pad after the excess I had in braking on track (wasnt driving like miss daisy either), he commented that he didn't want to source another set of Tarox calipers because of the rarity and he would like a more easily available kit. That's exactly what my kit is, everything is readily available and expendable including hoses, calipers and pads, the only thing that needs making is the mounts which most kits will. They are also one of the better conversions going as far as quality that have been borrowed from another oem car but the down side is that 280mm disks will be the biggest disk that you will fit under a 15" wheel due to there size.
Chip, do you use the turbo clio on the road at all?
Nicely summed up. After reading it through again what you have said makes sense, on Lesleys car 280 would probably be alright. Looks like chip started talking about brakes for his car though and wires got crossed maybe..? unless chips thinking about another turbo conversion and wants to be prept...![]()
material specs are the key difference there of course.
that and regulations speccing a 13" wheel
How the hell do they fit 278mm discs under a 13inch wheel?!
The wheels are very thing, and the inside is shaped specifically to allow brake clearance.
People need to stop thinking of F1 and road cars as anything like related for this sort of thing, the number of differences is huge.
On a more serious note what changes are you making, if any to rear brakes / rest of the brake system?
Even that car is SO much further from an actual modern F1 car than topgear would have you believe if you actually get down to the details. Its still gotta be about 20 years out of date at least and compromised for the road too.
Sorry mate, didnt see your edit.
No changes so far, but may need a brake bias valve to turn the rears down a bit, will see how I get on, the rear on my car does very little though already so I am hoping I will be ok.
Need to get back in the trader section and sell them as a kit!
