Clio mk2 ph1 COILOVERS
  Clio dymanique
will fk high sport 40-70mm (54mm) coil overs fit my 1.2 16v clio 04?
And will i be able to lower it at least 40mm with 17" alloys on with out rubbing?
Whats up with the Spax Coilies?
Steve
Poorly built and a hard setup.
O and they fail a lot.
if you have the right offset yep fine.
Chek your hub bolt spacing but you should have the 58mm ones which are easy to get coilovers for.
