Clio workshop manual - timing
  R26,172 & R5 GTT
Nice one lads, no its not for me its for my mechanic... the niggle was geting to the belt not doing it..
thanks again
  R26,172 & R5 GTT
has any one also got hints and tips to gaining access to get the belts off/on. that was the sticky bit.. it dosen't give to much info in the manual.
Jack the engine up and down once you've removed the suspended engine mounting.
Buy smaller tools/hands. It's a pig.
With the aux belt you can take the top bolt off the alternator and loosen the other ones so it can pivot down and give you a bit more slack than de-tensioning the tensioner alone. Careful you don't crush the air pipe that runs under the alternator though.
  Ph1
Your mechanic wants to know how to gain access to the belts and your letting him do a cambelt job on your 172? :eek: Brave
  R26,172 & R5 GTT
As mark123 said its a pig to do.. hes ben doing VW with 10 years, great mechanic but its even difficult to c how to get in there its so tight so its not the mans fault :rasp:!
