Change background image
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
CLIP
Discussion in 'Scotland' started by scotiamr2t, Jun 17, 2015.
  1. scotiamr2t
    scotiamr2t ClioSport Club Member
    Sep 5, 2013
    733
    Falkirk, Central scotland
    Car:
    Mazda 2, Ph1 172
    Anyone in the central area with clip able to assist in turning the air bag and service lights off?...............
    Carried out the usual resistor method and the lights go off initially then come back on 30 seconds or so later. starting to annoy me having lights on the dash
  2. rctempire
    rctempire ClioSport Moderator
    Oct 1, 2006
    5,593
    Scotland
    Car:
    Valver x2 & TDCI ZS
    I have said CLIP. But, still haven't discovered the magical turn off lights part yet.
    Will try do it this weekend.
    scotiamr2t likes this.
  3. scotiamr2t
    Sep 5, 2013
    733
    Car:
    Mazda 2, Ph1 172
    Thanks, come MOT time it wont be an issue anyway, just pissing me off having the lights on.
  4. -Jamie-
    -Jamie- ClioSport Club Member
    Nov 28, 2011
    1,003
    Tyndrum, Scotland
    Car:
    RS250 Cup
    SWR in Stirling will be able to do it
    MarcRâ„¢ likes this.
  5. Raymond_11
    Raymond_11
    Aug 17, 2012
    84
    Greenock
    Car:
    Clio 172
    I have put an n3 uch in my car and the passenger window or full beams don't work now can u do anything with that @rctempire
    Sorry to hijack
  6. MicKPM
    MicKPM ClioSport Trader
    Oct 4, 2005
    7,959
    Nottingham
    Car:
    Clio16v/225 Trophy
    That's most likely a damaged UCH
  7. rctempire
    Oct 1, 2006
    5,593
    Scotland
    Car:
    Valver x2 & TDCI ZS
    As MickPM said, sounds UCH related. What was up with your old UCH before this change? Did you get the ECU to match? They are both paired.
  8. Raymond_11
    Raymond_11
    Aug 17, 2012
    84
    Greenock
    Car:
    Clio 172
    Mines had a uch-hg went through a bit of a flood and water got into it and the drivers window wouldn't work bit blown u can see on uch. I bought a 2nd hand uch and Ecu and someone told me that it was uch which can be reprogrammed on clip to activate stuff
  9. MicKPM
    Oct 4, 2005
    7,959
    Nottingham
    Car:
    Clio16v/225 Trophy
    Certain options can be configured but general functionality is just part of the hardwares ability - CL, EW, Lights, Etc
  10. Raymond_11
    Raymond_11
    Aug 17, 2012
    84
    Greenock
    Car:
    Clio 172
    So you think the uch is at fault then @MicKPM
  11. MicKPM
    Oct 4, 2005
    7,959
    Nottingham
    Car:
    Clio16v/225 Trophy
    Afraid so unless the old UCH was doing exactly the same
  12. Raymond_11
    Raymond_11
    Aug 17, 2012
    84
    Greenock
    Car:
    Clio 172
    With the old one the drivers window didn't work as there was bit broken but if u crossed it out it would work also it didn't read the key sometimes so was on its way out but everything else worked
  13. scotiamr2t
    Sep 5, 2013
    733
    Car:
    Mazda 2, Ph1 172
    Bumpity bump, Anyone in the central belt with clip? I have tried SWR an the first they can get the car in is next friday, ideally need the fault diagnosed before the weekend so i can fix it
  14. rctempire
    Oct 1, 2006
    5,593
    Scotland
    Car:
    Valver x2 & TDCI ZS
    Send me a PM.
  • Share This Page
