Clio MkII 172 K reg
Hi everyone,
Did a search but everyone says something a little bit different.
My clutch pedal rattles especially when I push the pedal to set off. Wanted to check the cable and try to adjust it before I'll replace it. Can anyone write easy guide how to do it without removing any parts of dash. Usual Haynes covers it ?
The car done only 51K miles so I'm pretty sure it is not the clutch itself + I'm driving easlily most of the time. (172 FF K registry).
If I put my hand on the pedal when it rattles it will stop to do it so it must be related to the pedal assembly or cable.
Also, can't find the right renault part number for the clutch cable. Can anyone write this too. (CB1N)
thank you
thank you
