confused
  Petrol Blue 182.
found a set of fk coilovers for a decent price, but it comes up with the options for diffrent hole space sizing either 54 or 58mm, is that the hole in the engine bay where the top of the suspension joins up? if it is do i just mesure it? thanks
  Mazda MX5 1.8
no its at the bottom of the shock where it bolts onto the car
the tops are all the same
you'll probably need to measure it to be 100% although we could give u a good idea if u tell us the engine size/year
Martin_172
54mm probably but measure to be sure, your meassuring the spacing of the 2 bots on the bottom of the damper.
meassure to and from the same point on each bolt (bottom of the top bolt to the bottom of the bottom bolt or centre of the top to the centre of the bottom if you know what i mean.)
