Mondial Blue 172 Cup
Hi guys,
I'm chasing a bit of an annoying issue with my Cup.
My rear lights are proper screwy (typical clio disco lights)
I've done the usual, cleaned the contacts on both the light unit and the car, pulled the bulbs out and cleaned the contacts in the holders, pulled the earths off on the back panel but they didn't need sanding and looked spotless but my back lights are still screwy.
If I put the foglights on it gets even worse, reverse lights come on too if you indicate and then if you brake everything comes on and stays on.
Any ideas what else I could look at to try and sort this?
