Easiest way to adjust AST top mounts ?
  182, 6r GTi
i case of removing the top plate and taking the weight off of the coilover (jacking it up) ant then twisting the shock body?
or is there an easier way ?
thanks in advance steve
p@blo
  Clio/A3
Pay someone else? Are SRS?
Way you described is same as how i'd adjust mine. Jack it up to take the preload off the turret, loosen the bolts (top plate can stay on) & twist the damper.
Piece of piss. Shirley?
