exalto pe2's zr v vr
Dooby
  172 Cup
I had 2 tires fitted to the front today but they c*ck'd up the order. I have one of each. Apart from being more expensive and a higher speed rating is there actually any difference between the 2 tires.
  L'arctic Bleu Clio 182FF
where did you get it done mate? and how much?
Sorry, don't know answer to your question though....
  182 Cup
Hope this helps from Michelin:
Michelin do, indeed, produce 3 products in the basic tyre size & tread pattern mentioned:
205/45 R 16 83V ‘New Pilot Exalto (PE2)’ (V=Max speed 149mph)
205/45 ZR 16 83W ‘New Pilot Exalto (PE2)’ (W=Max speed 168mph)
205/45 ZR 16 87W ‘New Pilot Exalto (PE2)’ Extra Load (High load @ high pressure)
The ‘V’ Speed Rated product is the preferred fitment for the quoted vehicle model.
Initially, 2 products were available, but this situation was ‘honed’ down to the one product, listed above, ‘tuned’ to that specific suspension setup & fitted as original equipment.
The other 2 products listed are ‘tuned’ to different manufacturers’ vehicle models. The ‘83W’ product would be an option, only in case of difficulty with supply/availability of the ‘83V’.
The ‘87W Extra Load’ product would not be considered valid for the quoted model, being designed for a potentially heavier vehicle: higher load capacity at increased tyre inflation pressure value.
Thank your for your interest in Michelin.
Yours sincerely
Michelin Tyre Public Limited Company
Technical Support
Campbell Road
Stoke-on-Trent
ST4 4EY
Telephone: 0845 366 1535
Facsimile: +44 (0) 1782 403258
website: www.michelin.co.uk
