Couldnt pm you fella it said you cant recieve them. Anyhow yep the noise is from the abs pump but its a simple fix. Basically the abs block catches on its mounting bracket so when the pump cuts in you get strange noise. Loosen off the abs block mounting bolts,lift the block up slightly and retighten. The abs block is on the bulkhead on the gearbox side.
