Fitting FK Led Lights
cjgower
Was wondering if some of you can help me out. I've recently purchased a set of these:http://www.venommotorsport.com/product_details.php?id=1580&manufacturer=FK&category=Lighting
And used this as a guide to fit them:http://www.cliosport.net/content/guides/fubar/cluster_guide.pdf
I'm still having problems with these wired in. Brake lights won't work. Rear fogs do. LEDs won't work themselves, and for some reason front side lights are no longer working. Just a minute ago the dials started flashing, the whole car was like a disco.
I've spotted my left side connector has an extra blue wire, which is slightly lighter. Could this be why? Any ideas where I'm going wrong?
cheers
  Changes to often
om mine there for a ph2 and they just plugged straight in, so if they dont the ones you have will be for a ph1, im sure there is a thread on it some where with a wire diagram. the only thing i rewired in mine was the little white clip for the rear lights and brake lights, i found it crappy and lose which didnt give a good connection so my lights didnt always work so just replaced them with spade connectors.
cjgower
Cheers mate. I've wired them in as the old style using the guide, but now everything but the actual lights work. Brakes, fogs indicators, just no main light. Also lost dipped front lights and dashboard light. Fuses seem ok so not a clue what I have done
