flywheel
  Clio 1.8 16v MK1
Hi,
Is a Renault 19 flywheel the same as a clio flywheel(the 19 flywheel is from a 1.8 16v?
My flywheel got chewed up and i've swapped it over for the 19 flywheel but still got a clio starter motor and its making a grating noise.
Should i try a 19 starter or could there be another reason?
Cheers flash
  Clio 1.8 16v MK1
Its a clio 1.8 16v 92. not don't know the age of the 19 engine.
what you think the grating noise is?
should i try a 19 starter motor?
Like you say though, can't imagine there being a difference in the amount of teeth.
  Clio 1.8 16v MK1
Its been on and off a few times but i'll give the face plates a really good clean and let you know. Cheers
  Clio 1.8 16v MK1
well tried a brand new one from renault but same problem, so different flywheel and a different starter motor
  Clio 1.8 16v MK1
is there a chance that my bottom end bearing has gone and its throwing my flywheel about? it feels fine to drive though
