Good Products for Fiesta Sea Grey MK6.5
  BMW 330ci
I have got a sea grey Fiesta Zetec SMK6.5, it looks a pretty tidy car exterior wise, I just want to keep it that way. What kind of products should I be looking at getting, ideally to remove/ fill swirls, and give a good finish.
Products Ive got:
AG SRP
AG EGP.
Meguiars Endurance Tyre Gel
That is my list of products, not a lot I know. But I do want to get a build up a good products and then maybe move onto a DA later.
Any help would be appreciated.
Brad
You won't have a very clean car from only using those products ;)
Cant recommend everything as I don't have the time right now, but you'll need some wheel cleaner, I'd recommend something like Valet Pro Bilberry wheel cleaner:http://www.i4detailing.co.uk/acatalog/Bilbery_Safe_Wheel_Cleaner_2.html.
Just spray on and agitate with an EZ detail wheel brush: http://www.i4detailing.co.uk/acatalog/EZ_Detail_Mini_Brush_1.html
and Valet Pro brush for the fronts: http://www.i4detailing.co.uk/acatalog/Valet_Pro_Chemical_Resistant_Wheel_Brush_1.html
Also the Auto Finesse range comes highly recommended and you won't go wrong with many of the products:
http://www.polishedbliss.co.uk/acatalog/auto-finesse-car-care-and-detailing-products.html
Sorry for lack of a decent reply, hope it helps.
  BMW 330ci
I have glt a wheel cleaner probably not the best granted. It was from tesco called. Hot wheels or something. It is actually really good stinks terrible though !! And disnt last long.
Eill look into the auto finesse
Thanks for your help mate, much appreciated.
If it's Meguiars Hot Wheels then it will work well but it is acidic and can dull the shine on wheels, Bilberry is PH neutral, or thereabouts.
As a general rule, try to get stuff that is PH neutral as it's less harsh on finishes.
What stuff are you using for cleaning everything?
A good finish is all in the preparation ;)
  BMW 330ci
No it was some stuff from tescos, hot wheels or something. Actually looked and worked the same as iron x. Was really good for £3. But will bear that in mind.
Meguiars Gold Class. Don't get me wrong the car always looks clean, just want it to look the best and fill in/ remove some swirls because they are bugging me, and dont think Im confident enough to get a DA just yet.[FONT=Arial, Helvetica, sans-serif]
[/FONT]
  e92 330i
Maybe some iron x and tardis, a clay bar and clay lube. Then a sealent or wax as you already have srp, zaino 6 is well recomended.
