hello all.
can anyone tell me how to remove this bloody thing.. I took the motor out and then the 2 bolts under the dash and the one on the front once id removed the black panel behind the foam. all wiring moved and box loose but would not fit out of the gap even with the inlet removed
it came out in the end in little pieces as I broke it away in anger.. all because the little rad inside has a leak but now need to replace the whole thing.. some tips on re fitting would be great though and I thing ill loosen the plastic piece that it slides into over the heater matrix..
any help will be great...
jay
jay
