Burg 172-Charge Ti Duster
ive recently changed from standard 172 wheels, to a set of turinis.
Am now experiencing rear knocking noises every revolution from BOTH rear wheels at slow speeds, goes away 20mph +, which i never had before. old offset of 48, new speedline offset 38.5 (cup wheels) also the Wheels are tight as onto the hub, shock lower bolt is tight.
Iv jacked it up, wheels off, and there is no play in the bearings, but the pads are binding on the discs somewhat more than I think is normal. Rotated the wheels with handbrake off and its happening still. Warped discs? Uneven pad wear? New discs n pads time?
Ive also got an ABS sensor ring issue where the car seems to thinks its skidding all the time. Thats going into to rentech for that problem, but could this be a contributing factor?
Ive searched knocking noises but nothing has diagnosed anything similar!
PLease help someone! Driving me bonkers!
