lights
  clio 1.2
h can any one help me please i have noticed that my rear passenger tail light is not working and my front passenger side light is not working i have checked all the bulbs and they are fine could it be a fuse thanks.
  Evo 8 MR
What do you mean exactly when you say you've checked the bulbs?
Have you tried a different bulb?
  clio 1.2
hi sorted it now it was a 10 amp fuse the number plate light fitting was blowing the fuse for some reason so will get a new one and hope it don't blow the fuse.
  PB172,dci100,dci65
hi, just had some pleasure with the rear number plates light. It can blow the fuse when short circuiting somewhere. I did it when bending the plates in the platelight so they push more to the bulb...but when the bulb was out...they met and the fuse was gone. Now I have to change bulb with lights off and turn them on later to check.
