Been having a water leak the last week and thought it was a little problem, turns out to be a hole in the radiator, how much is a new radiator going to cost me, is the reconditioned option a good one, is it a renault only part?
Also the sump gasket is leaking, I'm assuming these are only cheap, is this a renault only part.
Also I need new pads on the front, recommendations on a good set, car is not used on a track but is there any cheaper/better ones than normal renault pads
Also need new discs and pads for the rear wheels, I think I remember someone mentioning having problems with the rear disc because of the bearings, is this true?
any help would be much appreciated
