Mk1 Boot lock
  '91 Clio RT =D
hi there, when I first bought my mk1 the key I have opened the boot, all was great
Now it doesnt :(
Have you guys got any idea?
Cheers craig
  Some of a Clio 1.8 16v
It's only really gonna be the lack of use means the tumblers in the boot lock get stuck in place by light corrosion meaning the key doesn'shift them.
All you need to do is use something to lift the flap to one side and squirt some lube (WD40 with the stray is ideal) in through the key hole. Then just work the key in and out until it starts to free up.
  '91 Clio RT =D
oh ok cheers mate :)
The key fits in fine it just doesnt unlock it
I will try this and let you know :)
Thanks again
Craig
  PH1 172, E39
had a similar problem with my megane classic.
you have to take apart the looking mechanism and check the internals.
