Mk3 blower wouldn't go full blast
JP83
South Central-Oxfordshire
Morning all...
Jumped in the car this morning and the screen was a bit misty inside. Whacked the heat up, and put the blowers up.
However, level 4 wouldn't work. 1,2,3, all fine.
I had the rear screen demister on, but I don't remember that ever causing a problem before.
About 10-15mins into my commute though, full speed on the blowers would work again.
imprezaworks
  Mk5 Golf GTI :)
heater rear stat (ref the fan speed). quite common to go, normally 2/3 go, or 1/2 etc. Is it working now?
  Suzuki Jimny
Quite possibly. I think it's because it's not up to temp yet so just does 75% power.
imprezaworks
  Mk5 Golf GTI :)
Cant say i've ever noticed that it wont work on the fourth setting with scenic, meganes etc that come into our place. Bit of a pain to replace :(
imprezaworks
  Mk5 Golf GTI :)
It's the stat more than likely.
Hi renault. Do you sell lots of stats to fix the blower issue. Yep.
imprezaworks
  Mk5 Golf GTI :)
Just did a quick google as i'm in work, i 'think' its behind the glovebox area or behind the dash where the fan switch is. Give any Renault dealer a ring and ask for the parts dept. Reg of your car and they will tell you,
good luck.
