New brakes all round, somethings wrong
  Clio 182, Astra Sri
hi there,
i wonder if any of you could tell me what problem im experiencing
i fitted new: oem rear discs, front brembo Hc discs and carbone lorraine rc5+ pads all round
everything seems to be fitted correctly etc.
but...
im finding that braking power seems to be hit and miss. in any kind of driving style
for example, i can slam them on and get pretty good braking, but then i try same again and its no where near as aggressive. or even wait ten minutes and the braking power doesn't feel the same as last time.
i can drive steady, come to slow down gradually and find that sometimes i have to use no pedal effort at all. or sometimes im pushing down on the pedal alot!
ive tried all sorts. double pumping, gradual pedal etc
didnt seem to have this problem before.
but i really dont trust my new shiny brakes :(
what could it be?
many thanks for any replies
JB
-J-
  RS2'ed 172 Cup
Have you allowed the brakes to bed in yet? Or are you saying the pedal goes to the floor when braking sometimes?
  Arctic Blue FF 182
Carbon Lorraine's don't need bedding in really, the only advice given is that with new disc's the braking system should be warmed up progressively, but no bedding in is required.
The bite from cold with RC5+ isn't great at times, but by the sounds of it, there doesn't seem to be a pattern to when your brakes seem iffy.
  Clio 182, Astra Sri
I've given them a good amount of heat cycles
70-30, allow to cool, then same again etc
Done nearly 300 miles since they were fitted also, and still no joy
  Clio 182, Astra Sri
I initially thought that It could be a cold pads problem, which would indicate why they say not for road use as they would become too cold too often
But even when they are warm it's hot and miss
  Clio 182, Astra Sri
Yes pads slipped in fine.
By pad carriers do you mean the flimsy bits of metal that are in the callipers, then Yes, they are still present
  182
I only asked as some pads are sized so they only fit freely without them. No harm will come by trying without the metal bits - but seing as yours went in fine then it's prabably not the issue.
  182
What would happen if they fitted in too snugly?
As one side was easier than the other iirc
Did you get new pad carriers?
My experience is that they should be free but quite snug in a road car. For track they should definatley be free and even a little play as the expand with heat. It's up to you if you keep them, I got new metal carriers with my pads and so I used them but took a file to one of the pads that was still a bit tight.
If they fit too tighty it will have a noticeable wooden and inconsistent feel in the pedal
  182
Bleed the system through with new fluid (ATE blue fluid for example) .
Old fluid/not bled recently can cause issues.Tbh i would have done the fluid at the same time as the full brake change
  Clio 182, Astra Sri
I didn't feel confident doing it myself as I've never done it before, I'll leave that to the pros until I've learnt how
  Dodgy one
They would bind and drag, did you give your brakes a good clean up and clean and grease your sliders up? I had a similar experience when one was siezed, brakes were a bit hit and miss i knew what it was it were just to cold to sort lol, i wouldnt remove the metal spacers either probrably find your pads will syart rattling about and its bloody annoying! If they are tight take a file to them just do it bit by bit testing them as you go
  Clio 182, Astra Sri
I think I cleaned them up pretty good, didn't grease anything
Didn't think it was necessary
I haven't removed the metal things
Not sure where you mean to grease?
  Clio 182, Astra Sri
Abs light has come on this morning
And the traction control light
And the service light
Wtf is going on :(
  220 Trophy
I wouldn’t have put RC5+'s in the rear as they're probably not getting warm enough to do any braking. Pop your old OEM pads in and see if it makes any difference. Whatever the problem is just stick with OEM pads in the rear.
  182
Wtf is going on :(
Check the brake fluid level and see if the cap has been put back on,as some people remove the resivoir cap when fitting new pads as it makes it easier to wind/push the piston back then forget to put it back on.
Was the little spacer behind the rear discs refitted?
  Clio 182, Astra Sri
Now this is where I sound like an absolute idiot
We didn't open the fluid cap because we couldn't find it lol (holds head in shame)
As for the rear spacers I do believe they we're refitted yes
Remove the engine cover and its against the bulk head at the left hand rear corner as you look at it, ok so the cap didn't come off but check the fluid level isn't to high as i think this also causes problems.
Ideally you could do with popping it into someone and get the system bled
  Clio 182, Astra Sri
When gently braking, it feels like I'm stepping on bubble wrap
Feedback through the pedal is like popping/fizzing
Weird lol
  Meg RS,172 and a dci
possible abs pick up ring cracked,that can cause abs light to come on and weird feeling brake pedal.
  182
Bloody hell who fitted them??? they should steer well clear of cars in future.. could have ended in a serious accident!!
