Okey some very clever person must know
  Lunar Mk1 & Flamer
Valver oil guages!
Any body know what pin is what?? And does it deffo run on 12v?
Valver Main Guages LCD
Dossnt work on my little 1.2 :-( everything else does can it work? what do i need? or am i looking at the pie in the sky?
Thank you, you clever bunch of people!
matt
  Lunar Mk1 & Flamer
going for the look mate! been sucsess full with the temp guageconnected it to the one in the dash! and the other 2 i can get to go up and down on a 12 volt swich! lololololol
know if i can get the lcd to work or do i need senders for that aswell?
LCD is the temperature - easy to add that stuff.
Other senders just plug them in and they will light up - just not do anything
  350z & 16v Maxi
I am having a problem with my digi temp display, it is not lighting up.
I have taken the dash out and a have a yellow wire come out of the connection block that goes into the gauge. Can anyone take a pic of of the plug so i can see where this yellow wire should go. send the pic to mailto:colin@dp-motorsport.co.uk">colin@dp-motorsport.co.uk
