Clio MkII 172 K reg
Hi everybody,
I read Edde's post about clio common problems that says this:
EDDE:
Anybody can post the renault right serial number of this part (182 PAS return pipe) so I could buy and repalce mine. Mostly because of the sound that mine 172's PAS make that just get my nuts.
Thank you
Lior
EDDE:
5) Another area of problem is the noise caused by a pressure build up in the PAS (power assisted stearing) system this is caused by a restrictive PAS return pipe. The modified pipe is a lot bigger and the one which can be replaced as part of the warently work (as of 6/3/05 this part is not on the Renault tech system) . All 182 come with the new pipe.
Thank you
Lior
