Punto/Clio GTT
ordered *excited*
Me too! Waiting for the delivery is going to be a biaatch. Just had a mail from the shop to say that some of my kit is out of stock too... bugger. I was itching to get started on it before the weekend.
Arctic Freezer 7 PRO
Seagate 320 GB SAT2 3320620AS
Antec Performance One P182B ATX
Intel E6600 775 2400 BOX1066 4M
Foxcon 320 D3 X 8800GTS-OC VT2D R
Geil DDR2 2GB 800-444 K2 GEI
Asus P5B Delux. P965 F RG SA
Enermax Liberty 500W ATX2
pretty similar to yours!
In terms of building the PC, its quite simple tbh.
I usually put the DVD drives and hard drives and power supply in place first as they are often impossible to remove once the motherboards in (found out the hard way a few times lol)then put in the motherboard.
You then need to seat the CPU and heatsink (instructions are provided, though its simply a case of lining things up and pushing in). Some people prefer to assemble these before puttin the motherboard in place, which tbh is often easier, be careful to use non conductive gloves and place it on the foam provided to stop it shorting out.
After these are in, add the RAM and graphics card, then you'll need to wire it up.
This should be quite straightforward, refer to your motherboard manual to find out where fans etc are plugged in. The big power plug to the motherboard is obvious, and the SATA power cables are also unique.
Overall, as you said you have some expereince it should be quite straightforward
If anyone else remembers somethin i forgot feel free to add it
i kinda see the idea, i think
do you mind me asking you how much this all cost? semms a preeety nice setup
Should I buy A or B?
If you don't know enough to know whether A or B was best, by definition you'll never know if you bought the wrong one.
Psychologists tell us there are two sorts of people. There are the people who put huge effort into getting every decision right, and worry endlessly whether they did. And there are the people who make what seems like the best decision at the time, and make the best of it. The psychologists tell us its the latter group of people who are far happier and more satisfied.
Very deep but ....eh?????
came today, built it, only problem is i gotta reformat my harddrive so currently burnin off essentials like photos n that.
but plugged it in, popped in vista, started setting up, not 1 problem.
putting it together was very very easy, no problems with anything.
only bad thing i did was trying to remove the metal blanking plates from inside the pc here the dvd drive goes, ive twisted, twisted n pulled and my hands caught 2 spikes, straight through, 4 cuts, 1 could do with a stitch but itll heal i guess.
apart from that fine!
great case aswell, cheers for recommending it, looks mint
balls, ok came to a problem.
put vista in, it goes through set up, asks what drive i want to install vista on, choose my harddrive and this comes up
Windows is unable to find a system volume that meets the criteria for installation.
and thats it, tried reformatting the drive, tried switching ide cables, made sure thyere in properly.
ideas?
